IH 2550 loader what models fit?
I would guess the larger 06;56;66;86 tractors with correct mounts. With just a bit of 'work' it could be put on a multitude of any brand/color out there. Might be easier if you told us what tractor you were installing it on.
Thanks for the help it came off of 464 that I am retiring and I am looking for a tractor about 20 hp more and probably 20 years newer to put it on I saw on craigslist there was a case IH mid 1990s model that have the same loader on it I think it was like a 50 hp
Hi, my brother has a 2250 Quick Attach model on his 3230(new version of 584). It came off a 495 which has same frame as your 464. His 2250 loader side mounting rails had 2 sets of holes drilled in it. I set was for 3 cyl 454/464 and the other set was for 4 cyl 584, 684, 784, 884 and newer series of tractors.
See: http://partstore.caseih.com/us/parts-search.html#epc::mr61299ar756950
The only problem we had was with bracket item 10, it had to be turned the opposite direction on 3230 and when it was made manufacturing had forgot to drill one hole on one side only. We drilled the hole and everything fit properly. It is possible that 4WD drive 74/84/95 series tractors require a different loader frame.
JimB
