I was blading my road with my 560.After using it about a hour noticed I was having trouble changing gears from a stop. ( grinding in first or reverse) I tried using my T/A from high to low and it worked fine. I have never had any problem with clutch or T/A . I checked travel and adjustments look ok so I whent ahead and greased clutch and T/A pivot pins. I used it some today and It is working ok. I do not understand what could have changed. Any suggestions on what happened?
You need to adjust the T/A-clutch linkage. Do not guess, use the steps in the manual for your tractor.
