Checked the dip stick and the radiator on the Super A. Oil up a quart and white, radiator down. So where is the water getting into the oil?
I have known for awhile that the engine needed an overhaul since it would smoke badly when first starting up. Probably a bad valve guide.
Now I have water in the oil. Was hoping to push this off till I got the haying done this season and then put the A in the shop to do the rebuild. Wondering if a bottle of bars leak might solve the problem temporarily to get through the season or do I need to pull some other projects out of the shop and put the A in.
Is this a head crack?
Bad Head gasket?
Not sure if A has the sleeves that might be leaking?
THoughts?
Marvin Johnson in Olympia Washington
Bad Head gasket?
THoughts?
