super MD exhaust manifold
P I Pete
Hi all, I'm looking for a good exhaust manifold for a super MD. I will be going to Lesuer swap meet Friday, if you are going there Friday and have a manifold, put a post on here. thanks Pete
You may want to check craigslist. They do occasionally show up there. Also anyone on there that say they are parting out tractors send them an email to see if they may have one that is not listed as of yet. Otherwise Ebay is probably your best bet unless you know where there are tractor salvage yards. We used to have a couple around me but they are all but gone now.
How are the Supers different than the MD? (Not that I have either) I could sell you a couple for a WD-9.
Most M through 450 are the same manifold. 400 and 450 have a longer bolt on exit pipe. Maybe all are the same but I can't remember if some early ones have a slight difference, but all will bolt on.
The manifolds are the same from 1940 and up, only differences are that the crawlers have a shorter pipe. And as dave said the 100 series may have longer pipe, the manifold body will be the same. Steiner sells replacement pipes for them as well. Jim.
