Harry in Ky
- Location
- Central Kentucky
I'm trying to remove the cover from the range transmission. Having no success as of yet. I have the park shaft up as far as I can get it and wedged as such. Have the cover off the left side, and can see the vertical reverse shaft is clear of the reverse fork although the fork won't slip out yet because the shaft can't quite lift out/up enough. The cover is loose, and will come up 1/2 to 3/4 inch all around, but won't lift straight up. The park pawl appears to the obstacle. What am I overlooking or what must I do next to get this thing apart? SOMEONE out there has been there before. What was your trick?
