Ron in Nebr
On my 450 gasser I have an aluminum live pump in front of the distributor. It has the two hard lines that bolt to the bottom of the pump with o-ring seals between the
pump and plate the line are attached to. All factory I think.
It started leaking the other day so I replaced the o-rings with some out of an assortment we have. Thought I had them matched up perfect, but it still leaks after I put
it back together. The old o-rings had no obvious cuts or flaws and I thought I had the replacement ones matched up perfect. Do these use a special o-ring? Couldn't locate
any in the parts available from this site.
Any other possible/probable causes of a leak here? It's for sure coming from between the pump and the plate the lines are attached to, so not a cracked line I dont
think.
think.
