A mounted cultivator
notjustair
I feel about three-fourths worthless. A neighbor plants an acre or two of sweet corn. Last year it was a weedy hot mess. I told her that I have a mounted cultivator for an A, so now I am trying to remember how it goes on. After messing with it all afternoon I have the front shovels on and the lifts adjusted right. I think I have found all of the parts for the rear shovels but I can't remember how the lift apparatus looked. I'm pretty sure I remember what my hands looked like before all of these blood blisters, though. Does anyone have a shot of an A from the back with mounted cultivator shovels?
I can farm a thousand acres and raise hogs and cattle but it took me all day to figure out this tiny tractor. ITS EVEN MY TRACTOR! If you don't use it you lose it - I've certainly lost it.
dont worry it will come back to ya,, last time i put a plow or sweep in the groung was in 1981 just befor i went into the Army, this past fall and winter wife and i got us a cub and a super c, it did not take long to figure both out and now we got the makings of garden if the rain dont wash everything out
bass
53superC
Does the rear lift with one lever mounted on the drivers platform or do you have a piece that goes on the left side from the levers to the rear. If you have the lever that mounts on the platform the square holes go to the rear and the front mounts by the brake lock. Rear rockshaft is different between the two types of lift. You do need to remove the drawbar to mount rear tooling.
I don't have anything that mounts by the brake lock. There are double handles by the gear shift. The left runs the left gang and it appears the right will run both if the collar is adjusted right. There is a bar running back that would have a handle mounted to it (I have yet to figure out what I did with that). The rear bracket that spans the back end has an arm welded with a pin welded to it. I assume that will attach to that adjustable handle.
It just seems like a lot more to do at the end of a row than I remember. I thought just one lever ran it all but I might be imagining things. It's been a very long time since I have seen it mounted.
The bar running back is it attached to the two lever set-up. That bar goes on the left side back to the rockshaft like you said one lever lifts the whole thing. That rockshaft is different from all other rockshafts used on the cults made for the A
