504 Hitch Lift Lever
Am posting this for a friend. He has a 504 and says the hitch lever fall down after raising as soon as you release the lever. Am looking for advice. TIA
If this is the 3 point lift lever there is a friction disc that may need tightened.or replaced , if I remember correctly.
Yes, there is a friction control disc with a couple of lock nuts that are in a difficult place to adjust. Just follow the lever movement and you will see them. Assuming Farmall model, not sure of the utility.
