Fast Hitch plow help...
Farmall43
I have two fast hitch plows. one is either a 311 or a 312. The other is either a 411 or a 412. I am looking for the rim and tire for the tail wheel. The 3 bottom is a 3 bolt rim. The 4 bottom is a 4 bolt rim. Any ideas on where to find these? Also I am having difficulty finding the dished style coulters that are on the 3 bottom. It has 2 good ones on it and one that is junk. I appreciate any assistance that is available.
Matt
The wheel-rim , you will possibly have to cut the center out of the old one and weld in a new wheel.
Well i am not sure where your from but when you said DISHED coulters on the 311's Wonder if that set was once mine ??? as i installed three M&W coulters on mine to keep from plugging in corn stocks the first year i had my 450 D and they were my first set of plows . If they are M&W's then what you use is a 7 Ga. 18 in disc blade with the 1-1 1/8th square hole
I m in Michigan. The plow was purchased at an estate auction I think in 2002 or 2003. It has a sod buster bracket and arm on it but is missing the sod buster.
Had the same Issue with my C-20 plow with 4 bolt tail wheel--- I bought 542488-R1 and it works fine. Sorry can not help with the three bolter
Try Duffield Equipment for rims. Just type in Duffield Equipment and a link with IH equipment parts will show up-- I think the guys name is Mike super nice fellow I bought a couple of plow chief moldbords last year. He had all styles and sizes of tail wheels
