Lyle Knight
I have a 1962 Farmall 560 diesel that has an aftermarket temp gauge. Today I was running it, not pulling it hard and when I got back to the yard and idled the engine down to about 700 rpms, it started to get warm. It got to 190* and when I run rpms up to 900-1000 rpms the temp will drop to 160*. It has never run above 170* before and that is when pulling a load. I took the radiator cap off and with the engine running I do get a bubble every so often, but the oil looks fine! If I run it down the road in high gear the temp stays between 150*-160*. Is this normal, or do I have a head gasket issue?
