urbancase
update from my last post the other week, since my last post my parts guys felt there was a problem with the rebuilt pump i got so they had another one sent and got it put on wed night and still will not start. redid the timing and checked to make sure all marks line up on the gears on the motor. this is a d206 motor put the injection pump timing mark on number 2, lined the crank at 14 deg before top dead center and then lined up the mark in the injection pump with the time mark inside the pump and will not fire. it will take off with starting fluid with no problem, cracked all the lines on the injector to make sure fuel is coming out and no air, and i have fuel coming back for the return line. everything in the motor is new and keyed and i check for top dead center when doing all this. pete 23 and curt and others i am out of ideas and lost of what it could be. i am open for an idea.
thanks guys
thanks guys
