Fast hitch grader blade
1legonutt
Here's a picture of the drawbar.
Rob
wow indeed does not look too "fast" a hitch up to me, just sayin
AND is that a factory issue ? I have the same plow mounted on a 300U only it's out front.
cool
<image src="http://forums.yesterdaystractors.com/photos/mvphoto19289.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto19290.jpg"/>
WOW if that is not factory you did one bang up job! I looks like a beefy version of what goes on my Cub. You get smoother grading that way with less wash boarding.
to 350 Dave would you mind showing me some more of the connecting links for you front mount blade I am looking to design a front mount set of front mount equipment such as a blower and flail mower each with separate engine for farmall and needing ideas to follow
thank you.
lol that's not for the plow and it not all of the solution
<image src="http://forums.yesterdaystractors.com/photos/mvphoto19295.jpg"/>
I think the same blade can be mount both under and in front of the tractor. Takes a few additional parts to do each. I have one for my Farmall A mounted as belly blade (no hydraulics) and one for my Farmall Super C mounted in front.
Someone on red power forum was asking about the grader blade its a pain to post pictures there so I told him to look here just trying to help a brother in need.
Rob
OH you are FUNNNNY! I got a good chuckle out of that. We had a 55 gallon drum with a big steel bar through it. Fast hitch on the 300U. Then at the cement plant they poured it full from the tails on a truck. Wanna guess what a 55 gallon drum of cement weighs! NEVER had any traction problems but only on ice. If I remember my dad used the axle from a broken model "A" rear. Fits perfectly.
