Just bought this tractor to blow snow with next year. Mostly in good working condition. Starts and runs great. Power shift works great.
First of all. All my local dealers cringe when I call them about this German built tractor. Does anyone know a good source for new parts for this tractor? For the time being I need a rad cap, and a seal for the draft control plunger.. and proper filters.
Secondly. My main concern is that the PTO hand operated clutch does not work. I can not engage the PTO with the tractor running. I also notice diesel fuel leaking from the fuel tank, and dripping from the bottom of the bell housing - wondering if this has soaked the clutch and caused some damage. The hand clutch does have resistance, as if it is pushing the release bearing+pressure plate, but maybe not far enough. My manual says to adjust the lever itself, but my lever is solid and not adjustable at all. Any tips?
The manuals I downloaded on-line are pretty vague. Does anybody know how much I can see through the top bellhousing inspection cover? Can I inspect the PTO clutch as well as the main clutch?
Any help would be great.
