560 question
Taylor88
Does a 560 Wheatland tractor have the same ring and pinion (15:49) as a 560 row crop? Also wandering if all transmissions gears are the same too.
16-49, transmissions are the same. All have the option of high speed low and reverse and heavy tillage 3rd and if I remember correct that means two options on the 4th speed also. If you want faster look into ring and pinions from the SMTA, SW6TA through 450 series tractors.
