jsfarmall
The ID plate on my cub is damaged and not able to be read. Anyway I can get my serial number and punch it to a new plate?
No, unless you or a previous owner had the number written down, maybe a sales receipt of when the tractor was sold or something. There would be no record otherwise that I know of. BUT, there should be an engine serial number on the block. Someone will weigh in where to exactly find it on a Cub. If it were me I'd use that number and mark it on the new tag as such. (eng # xxxxxxxx) Some engine numbers match the serial number but not always and especially if the engine has ever been changed.
There is nothing at all able to be read on my id plate. I was just wanting to get one and stamp all the info on it if there was a way to get all my numbers. If not I won't waste my money on a plate.
If the original number was stamped with a heavy hand, you may be able to read the digits from the back side. Most of the time, you can't. Otherwise, the engine number can get you a rough idea of the serial number, but not exact.
