Just got done putting my 706 back together after a major overhaul. Never had a problem with it charging at all now it wont charge. Went ahead and bought a new alternator but that still doesn't solve the problem. Anyone have any ideas? I would say its in the wiring somewhere because shouldn't one of the wires on the plug in be hot when the key is turned on so that it excites the alternator? if so I do not have that.
Well you had it apart and moved bent tugged and pulled the main wiring harness so you may have broken the big blue wire or the yellow wire . SOOOooooooo get your handy dandy Oham meter out and unplug the reg. wiring harness and unhook the wires at the alt. and see if you have a connection. Since i am not there to see for myself what all ya did i am guessen .
