Plow for 300 u
Dave S.
Will this plow fit a 300U, and what model plow is it? Will probably have to copy and paste the url.
http://stjoseph.craigslist.org/grd/4956952442.html
What model plow will fit a 300u?
Can't do the copy/paste thing but I have a 2 bottom plow that I would sell and I know for sure it fits a 300U because it is on a 300U right now. It is a 2 bottom disk plow and it works real good
(quoted from post at 13:19:02 03/31/15) Will this plow fit a 300U, and what model plow is it? Will probably have to copy and paste the url.
Small point Fast Hitch, but will work on your large point with a 1/2" spacer tack welded on the bottom.
There was a plow made specifically for the 300U with fast hitch. It has a top link like a 3 pt. I have one but it is a hike out there to where I store it and I do not know that it had a plate or identifier on it. Maybe someone can tell you what the model number is. I am thinking f-20 or uf-20???
Can't see the picture either, but I have a plow for a 300U that I will sell right. It is a 2-14s moleboard that worked good on my 300U. And Dave H is correct, the plow will have a place for a top link that must be used with these tractors/plows.
Just went on CL and looked at the plow on St Joe, Mo. If this is the plow you're looking at, it will hook up with spacers(as previously posted), but you won't be satisfied with the results. To do a good job of plowing, you have to have the plow specific to the 300U. That plow(which looks to have the small points) was made for the Super C tractor.
I have an undated IH Application Listing of International Harvester Fast-Hitch Mounted Implements for their Farmall and International Tractors. There is just a single plow model listed for the International 300 tractor which is Model U-F20 noted by Dave in an earlier response. Hope this helps but looks like you need to find that plow if your tractor is going to do a decent job in the dirt. It was made in two and three furrow models, Hal.
This is a F30 plow made for a 300U, A coworker has it in his shed, and the 300U it came on in the garage. He would be willing to part with the plow. This thing is in almost new shape, didn't get much use at all, they had a 450 to plow with. Said it was repainted once, maybe by the dealer when they bought it and it faded to an orange color, but I doubt you could find a better one. Plus no FLAT tires ever!
the cl plow is a 2C-20. as noted, it was made with the super c. it has been years since i used one on a 300u, but i don't recall it doing a poor job.
this is mine, that i use with a 200.
36530 is correct.I have a 300u and the same plow in 2 bottom.The plow without the top link will not work properly,but it may work on a SMALL,LEVEL garden spot.The only thing on 36f30's plow pic I disagree with is the fixed top link. It supposed to be adjustable,26,1/2 inches center to center,but sometimes I need to shorten it.Mine has a handle to do this from the seat. When you hook top link to tractor,you pin it in the lower hole on the rockshaft,if it has 2 holes. Some 300u s have a single hole-some have 2.The top link length sets your points to go into the ground. Make sure the down pressure pin is NOT installed!!!!It is the pin that lets the rockshaft float.When the plow is in the ground, the points should be pulling it down just enough so that the rockshaft l/s arm sets on the flat from the lift cylinder.Also your leveling crank must be lengthened about 5/8",I think.Mark
