Dennis@mo
I am not sure whats up. Need some advice. I drained the trans. oil on my super c along with the belt pully oil. I filled up the trans. till the over flow ran. I then put about 2 qts of oil or so in the belt pully and thought all was good. I checked it today and couldn't see any oil in belt pulley.What gives. Any help really appreciated. Belt pully should have oil in it. Correct?
There is a drain in the belt ulley letting it back into the tranny it gets itsd oil from the slinger gear throwing oil up into a channel that drains into the belt pulley. Now its possible that hole is plugged and not letting oil into the belt pulley. If you arent using the belt pulley dont worry but if using then you do have a problem.
There was oil in belt pully..before I drained oil I took plug out of top and oil was pretty well covering the gears so the slinger must have been doing it's job.Pretty puzzling to me.
When you remove the fitting then turn the pulley over you will see oil being picked up so you know everything is ok.
