I have a Super A, no water pump. I managed to poke a hole in the radiator with a screwdriver..a small hole. Took it to a radiator repair...they tell me it cannot be repaired.
Well, it really looks kinda corroded in and out, so ok, time for a new one I guess. I specified I had the no-water pump early SA.
It get the new one home and notice that the upper hose is 21/4" while the lower is 2". On the tractor both upper and lower are 2". Also I notice that the tube configuration is different on the new one. There are 4 rows of smaller tubes running vertically offset from each other. The original radiator has 2 flat tubes one in front of the other.
Doing a little checking, this new rad is for the later Super A's with the water pump. Tells me it is the same as the early no water pump radiators, except for the top hose being 2 1/4" What everyone does is get a exhaust reducer, 2 1/4 to 2" and use that to hook up the upper hose.
Correct me if I am wrong, but aren't the later (with water pump) Super A's use a pressurized cooling system and the non water pump SA's are not pressurized, using a thermosiphon method to circulate the coolant.
So, the question is......is the different tube configuration on this new radiator a problem......seems to me it was designed with a pressurized, water pump driven system in mind, not a thermosipon system.
Thanks for you thoughts.
Scott
Scott
