Super C hydrulic hose
True Son
Does anyone know the size, both diameter and length, of the hydrulic hose or hoses that come out of the control on right side below the gas tank? These hoses go to the block on the deck of the tractor. I would go measure, but Super C is 120 miles away. One hose or fitting has a leak.
Thanks for your help, True Son
Sounds great... Then it's 3/8 inch hose. I can buy one at Farm and Home here, I think 4 feet long, for 6 bucks and change, but appreciate the
offer!! Going down to the farm on Wednesday. I think it's got male fittings on both ends, right??? True Son
I thought 4 foot sounded like a lot of hose so I measured mine, then I remembered I've got a parts book. Per the book both rear hoses = 1/4 x 29" one frt hose= 1/4 x29, one frt = 31 3/4".
I made both of mine 32" long. Fixed fitting on one end and swivel on the other. 3/8" hose rated at 4,000 psi. I think they were about $15.00 each.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto18384.jpg"/>
Thank you very much for your pictures...I'm on my way to the Farm Store to get me a couple of hoses and some fittings, per your pictures...very helpful...True Son
The original setup was with steel tube on the front. The 3/8" hose stared at the block to the cylinder. With all the bends that are needed to replace the tube hose is a good choice.
