I have a 1955 Farmall 100 that use to run just fine. Lately it doesn't run at all because it won't start. I pull on the starter rod and it turns over exactly once around and then goes dead. It won't do anything after trying to start it again. I then take off the battery cables and clean them up and try- again and it turns over once and stops. Is my starter somehow jamming / sticking? It's a 12 volt battery , just about new. The teeth on the ring gear look a little worn but not that bad (I don"t think so anyway. But I'm a greenhorn as a mechanic . I would appreciate some guidance i this matter. Thank you very much.
