My loader auxiliary valve is hooked directly from the pump, and then the pumps pressure is moved to the fast hitch through a power beyond port on the auxiliary loader valve. The way it is plumbed now I wouldn't be able to remove the loader from the tractor. What I'd like to know is if there is a power beyond port on the hydraulic valve that operates the fast hitch? If that was the case I could use that port to power the auxiliary loader valve. Then when/if I would need to remove the loader all I would need to do is unhook the hose, from tractors power beyond, and remove the return hose from the auxiliary loader valve to the tractors reservoir. Is this possible?
