farmall 200 hydro pump interchangability?
R&W
i have a farmall 200 with a c-135 with a bad hydro pump (part no. 3830113R94). but i want to get a new one for it but what part numbers will interchange with this? or off of what tractors? also what are the major differences in the pumps? i need one thats fast for my snow plow. thanks
If spread is your need I would use a newer version like a 240,340,404,424and
there maybe others you need higher gpm to move the blade faster .
Your problem probably isnt with the pump if a snow blade is what you are using. Is it a fast hitch or something else. Those pumps are pretty good maybe you have large dia cycls and not big enough hose for flow so more details on the plow are needed. Have you cleaned the filter and are you sure hy oil isnt getting into the pan does your engine oil level get hi have you opened up the top petcock and drained excess cause if the seal in the pump is bad it will pump oil into the engine.
its just really slow leaks and all the treads are stripped out and there are other things. i guess will one off a 340 work?
