1466 3pt not working
the 1466 the three point will not lift the oil is full and the lever works but wont lift what do you think is the problem? thanks
Try to pull the lever to full raised position. Then pull your scv lever to raise. If this raises the hitch, your unloading valve is malfunctioning. If not, could be just about anything else. Best I can do for you from here.
Pull the 3rd arm bracket off and look in on the right side and see if the linkage is moving when you pull the lever! Had a 1066 that the c clip fell off and let the linkage come apart and the 3 pt quit working! real bear to reach up in thier and put new one in but it can be done!
