Atilathehun99
Tonight I started the SC up for the first time this year. After starting with the charger I left it to run continuing to charge and I walked off to do other things. After about 20 minutes or so I noticed some smoke. Investigating further I saw it was coming from the back of the rear (generator) pulley on the fan/water pump/generator pulley assembly. Ok, so I know I have a shot pulley bearing(s). Looking online at an IH parts website I see the spindle/hub assembly/thrust nut (w/ oil tube) as 2 different parts. I checked Steiners and they show selling an entire assembly that includes everything excluding the fan itself. I'd appreciate thoughts on which way to go - IH pulley's only or Steiners with the whole works? I'm also assuming either way that I'll have to pull the radiator to make the fix? Thanks in advance for responses.
