bumblebee
I have a 1934 F 12 that I brought back to life. It runs really well and crank starts very easily when it is cold. Let it run 20 minutes, shut it off, then nothing.
I have put in a new condenser and coil and it still acts the same way.
My friend has a book on magneto rebuilding. It says that the resistance on the coil should be close to 6000 ohms. The old coil and new coil both measure very close to 12000 ohms. We used two different ohm meters and they read the same.
The old coil was stamped 1/90 and the new one looks exactly like it. The part number is eb108.
If any of you guys have any suggestions, I would like to hear them.
Thanks
Thanks
