super m MW hyd pump
So I just bought a live hyd pump today does anyone have any pics so I can see how to plumb everything to put it on my super m. I will be adding the Christmas tree valve too so that I can have two way hydraulics.
thanks Zach
This shows the main ingredients needed to use the M7W to operate a 2 way system. I would add a high flow filter in the supply (suction) line to the pump. The supply hose needs to be about 50% more cross section area than the pressure hose. The valve/s
must be open center type (meaning that it must flow from inlet to return to reservoir port when the lever/s are in the center position), These can be purchased for less and be more adaptable than a IH christmass tree. Valves, or stacked valves for more than one cylinder, can be found at Surplus Center . com, or Farm Stores. Jim
It's pretty simple, large suction hose from the drain plug on bottom of belly pump, connects to suction side of live pump. Pressure hose from pump to in port on valve, primary and return line run from valve to couplers, then the fluid drains from valve back into res. Through filler cap. Just remember large suction hose from res. To pump and disconnect counters haft drive to belly pump.
