340 internaional
harlydave
New User
I just bought it knowing hyd didn't work I check oil could see any in trans witch way do I go it runs great any help would help
(quoted from post at 08:20:51 03/22/15)tCheck oil untder clutch petal very small bolt.
k maybe I miss spoke there was barely any oil in it filled and still nothing what is that bolt under pedell for thank you
The bolt under the clutch pedal is the full check plug, you fill the trans until oil reaches that level. Total for the 340 is somewhere around 13 gallons I believe.
Did you check/change the hydraulic filter at all?
-Jordan
(quoted from post at 16:53:43 03/22/15) The bolt under the clutch pedal is the full check plug, you fill the trans until oil reaches that level. Total for the 340 is somewhere around 13 gallons I believe.
-Jordan
Ok the filter behind plate under. Clutch ped
(quoted from post at 09:02:32 03/23/15)
-Jordan
ok I found a lot of water in system took pump off hydraulic manifold water water water this would make it not work or might be something else any idea
