Instrument bolt for Farmall B
That bolt has the head welded on the inside of the box so the outside surface can be flush to the steering post. You will need to remove the head inside of the box then you can install a new one. 3/8 NF will work make sure the box has good ground when finished cause the lite sw needs also ground to the steering post for the gen to work.
