I have a spare block
I have a spare block out of a 44 H that I could use if the repair doesn't work or if I sell it later down the road. so I am good there. I am going to try to repair it for now it runs to dang good to rebuild it. might as well run it if I can right? If I keep it I am going to use it to pull trailers of wood out of the river flats and pull logs out to cut up so it wont be a resto. It will be a working tractor.
You might look into metal stitching. You tube For a lesson, it is a real repair that lasts permanently. Jim
