Good morning,
I'm looking for this center "pitman" arm as the one on my tractor has been welded up/bent/and generally worn out. If someone had the entire setup from a 200 or 230 or whatever/whenever they went to the actual tie rod ends that would be fine too. I'm not worried about keeping it stock as this is a working tractor.
Thanks in advance.
Thanks in advance.
