Cylinder liners!
Super51
May be a long shot but I am in need of two good used cylinder liners for 54 Super-C with 123 engine!I tore engine down many years ago with intentions to rebuild it but never did!Got to checking the only two that I can find and they are barley worn at all!These are original IH liners with 3 1/8 bore,6 7/8 to bottom of seating ring,7 1/16 overall length!
If they are the same as used in the A and B engines I may have a couple laying around. When I built my BA I used parts from a B and an A to build a BA. I think I still have the sleeves out of the one block
Hello,that sounds good,my liners had a very slight wear ring at the top,so slight a finger nail would not even catch on them,evem mic'ed them with inside micrometers and got very close to original bore size!What are you asking for two of those?
dont what all you have to put engine togeter. you might be interested in full set of new pistons and sleves for that engine. 3 1/8 bore slight dome on piston. will sell for 225.00 shiped to you .phone 989 912 0083 if interested
Liners from a stock A or B will not fit a late Super C. The Super C block has a slightly larger bore than a stock A or B block.
Some Late Super A's MIGHT have the right liners, but only a micrometer can tell for sure.
Hello,teddy52food,yes that is correct about bigger at the bottom where the o-ring goe's,mine measure 3 7/16 =3.437!
Hello fastfarmall,I did not know that the A and the B had the 3" from factory,then it would have to be an overbore to be 3 1/8 which is what I need! Thank's!
Hello old,could you measure your liners when you get time and see if they are 3 1/8 and if they are I can use them if just 3" they will not fit!Thank's.
Hello Duane Rushlo,I want to see what I can find used out there right now since I still have the original pistons that are in good condition!I will certainly keep you in mind if I go that route,that is not a bad price!Thank's.
You need the measurement at the bottom of the sleeve where the o-ring goes. The other dimensions are the same for other sleeves but there can be a difference at the bottom where the o-ring goes
I'm not sure where you are located but I have a complete set of pistons, rings, & liners that I took out of my 54 SC when I rebuilt the engine.
Hello xfarma,were those that you took out pretty good condition,were they cast iron pistons with cast iron rings like mine were?
Hello xfarma,I am located in Ky,let me know if you are still interested in selling those rings,pistons,liners and how much you are asking!Thank's!
Hello Gene Bender,going to 3 1/4 overbore highdome would give you how much horse power over stock?Also just wondering how much more fuel it would use with this overbore! Thank's!
