chad from michigan
ok I picked up a 47 farmall H got it running but first problem was found hole in radiator needs a new one and second the water pump is making a grinding noise yes its the water pump. can it be rebuilt? what goes bad? I am not sure what is really making the noise I just know it is coming from the pump/fan it a little grinding ticking noise. has anyone had this happen and whats the best thing to do? my dad has had 2 farmall H's since the 50's never had to mess with the pumps what goes bad in it?
so I need
1) radiator
2) fan assembly
3) starter button cast housing
4)2 front rims and tires (well just tires)
1 & 2 are a must if you Michigan guys got parts let me know.
so I need
1) radiator
2) fan assembly
