chad from michigan
Thanks
before I get all crazy with buying a used one I will pull this one off and take it to work and work on it at lunch. I am in the Instrumenttion Shop (small electronics) and the mill wrights will give me a hand working on it on break. They should know how to re-pack it. Hopefully the impeller is still good. Thanks for the help.
The radiator when I filled it up had a steam of water about the size of a #2 pencil flowing out near the bottom. Maybe I can get it plugged or solder it closed?
