super c hydraulic pump
Can anyone tell me what pump this is or what a part# would be for a rebuild kit. Hopefully the pictures show up. I don't always have the best of luck with pictures.
Thanks
maybe this time
looks like the one that is on my C. the only problem that i have had, is leaking into crankcase. most of the time it is the seal around the shaft.
here are the part numbers for the seals that i use to stop my hydro pump from a class I leak:
353183r91 pump-to-shaft seal
350708r2 pump-to-motor gasket
75285739 o-rings, pump-to- tubing manifold
bass
53superC
Here's a parts breakdown on your pump. You may need a speedi-sleeve to cover the worn grooves. Hal
