I understand how an ignition coil works, primary winding to secondary winding, and I understand some have more resistance so are called "internal resistor" coils, but wonder what the difference is between a true 6v coil and a true 12v coil? Are the 12v coil windings of heavier gauge metal, are there additional windings over the 6v unit, is there better insulation coating on the 12v windings, or what? Except for the additional heat generated, it seems like a 6v coil without an external resistor would work in a 12v situation, much like a 6v coil will work when using an 8v battery in a 6v system.
--Lee
--Lee
