Super C Cultivators
Does any one know the model of cultivators I have. I bought them from the mans wife so I know nothing, but were on a Super C. I would like to get a manual for them.
A quick google search for 'farmall super c
cultivator model number' turned up C-254.
I think all the letter series cultivators are very
similar. The ones for my H and SC are the same
except for the mount to the tractor frame.
Greg
What is the correct way to set the rear wheels for 34 inch rows.
That's correct on the c-254. To adjust your wheels put the cast center as far to the inside as possible on the steel rim , then slide it 6 inches from the end of the axle if they are uncut , once completed you should have 68 inch tread centers as 80 inches is all the way out.
Oh Lord I forgot measure there are a few SC tractors with a special 88 inch rear end , just get someone to hold the other end and measure it is either 80 or 88 across the back to axle ends if it's an 88 your hubs will be 10 inches from each end.
The C-244 is pretty similar, but I think this looks like a C-254.
Measure your current tread width, center to center. Whatever the difference is from that to 68" is how much you need to move them.
