super c rearend drain hole
bass
dumb question, but where is the drain for the trany on a SC?
i need to change the trans oil in Charlie
bass
53superC
(quoted from post at 07:21:27 03/20/15) dumb question, but where is the drain for the trany on a SC?
bass
53superC
It should be dead center under it inline with the axles if I am not mistaking. I may be thinking of something else. Please correct me if I am wrong. :idea:
if you have a draw bar, you will have to slide the draw bar, to the side , before you will be able to find it.
I have a fast hitch on mine, but as they said, it at the low point of the rear end inline pretty much with the rear axles. Have an empty 5 gallon bucket ready because it will come out in a hurry. The fill plug is on the drivers platform just to the left of the shifter. Level plug is on the right side below the PTO lever.
