1566 rear axle planet gears and sun gear no timing marks?
gillet598
I had to replace bearings on rear axle on 1566. marked axle position and planet carrier position on axle. all back together to the point of putting assembly back on tractor. however there is no timing marks on the sun gear or the planet gears. nothing anywhere. anyone have any ideas?
Dan
There is no need for timing marks. The gears "timing" changes with every revolution of the wheel. As long as they mesh correctly, you are fine.
