Egle Claw hitch
None that I am aware of.But there is a guy who makes a type of 'quik hitch' that would serve your porpose.
I've seen them on eBay but they all extend the arms by 3 to 4 inches and are bulky. I always thought the Eagle hitch was superior to the standard 3PH, too bad it didn't pan out. IMO
(quoted from post at 20:38:22 03/19/15) Does anyone manufacture aftermarket Eagle Claw type hitch ends which could be welded onto regular 3PH arms?
You'd have to pull a set of arms off of a junk tractor to get a set. Someone on eBay sells the latch parts if they are missing on the hitch arms you find. The claw part has about 3" that go into the tube. You can cut the tube apart to get the claw out, then you can weld them onto anything you want to use them on. But I don't think it would work very good on a three point that has swinging hitch arms. There are also quick couplers you can buy on eBay that you could weld to a hitch arm.
I have seen the eagle claw sort of thing on an Oliver 1600 I looked at years ago. I thought that was the best 3 point arms I had ever seen and they where the true 3 point type arms that had side to side play
If length is all that concerns you,just cut off the ball end and weld the 'claw' onto the arm.Just measure to keep the length the same
My neighbor bought an old 1800.He had me cut off the hooks and weld on balls instead.Still uses the tractor too
