ChasK
I have a few questions about replacing the regulator on a C. The first two pics are the old in original position. The next two are the new one. The three terminals from left are labeled "L" "BAT" "F". There is also one underneath on the back side.
#1: To which terminal do I connect my black wire?
#2: Do I need to use what's in the last pic?
I'm pretty sure the larger wire coming from the battery goes to the center terminal. Then to polarize, I jump the "L" and "BAT" terminals.
Tractor is 6 V POS ground.
Thanks for any help...
