W9 Drawbar (swinging)
Andrew Z
Does anyone have a picture of a W9 swinging drawbar? To me it looks like a drawbar that was used on a T9. I believe mine has been cut but cant seem to verify this. I have the book on this but only shows the fixed bar.
thanks
Andrew
nothing different about the w9 drawbar,same as all standard tractors. dont have pic at the moment.
The one I have looks to have had a 'double tang' instead of a single tang. IE a 'C' shape, ill try and get a picture of it this weekend
Not at home currently but it looks similar to the drawbar on this TD24 does that seem correct? (obliviously smaller but same idea)
https://walkerplant.files.wordpress.com/2013/08/td24.jpg
thanks
Andrew
Here's a TD 9
The 9 series tractors came factory with a double tongue swinging drawbar, very similar to the TD-9 picture already posted. I will try to remember take a picture. I have one WD-9 that has had 3-4 inches of the end of the top tongue sawed off to make it into a single tongue--my father was the culprit who sawed it off many years ago in order to hitch a Gehl 135 mixmill to our WD-9.
Thanks guys, that sounds exactly
what happed to mine. I'm going to
try and weld the to tounge back on.
Just wanted to make sure it was
correct.
Thanks guys
Andrew
He should have welded on a piece like the TD 9 in the picture. It would be better to cut the weld than butt weld on a piece, I suppose he didn't think of that.
hey Andrew I have some pics on my phone of a couple of wd9 drawbars. my number is 920-946-3875
send me a text and I will text you the pictures.
joel
This is the only type swinging drawbar I noticed for 9 and SW9 tractors. Would the other be a special drawbar.
This is in a 600-650 parts book. Same parts as a 9 and super 9 except numbers 1 through 6 and 11 and 12 and bolt length and # 13 mounted below bar.
