46 H TAIL LITE LENS
al71
IS THE TAIL LITE LENS ON A FARMALL 46 H DIFFERENT THAN THE FRONT LIGHTS. THE LENS ON THE FRONT IS #5936059 I THINK I NEED THE SAME # FOR THE REAR. I TRIED EBAY AND OTHERS BUT NO LUCK.
PLEASE HELP
At one time, the rear lens WAS different. It was configured to throw a wider beam of light, much like a floodlight. Don't know when that one was discontinued, but after that, the lenses were all the same. If you change over to the newer style, hang onto the old one. It might just have some value.
THANKS FOR THE REPLIES. THE REAR LENS THAT I HAVE SAYS SEALED BEAM AND CAN BE USED FOR RIGHT OR LEFT LENS BY TURNING IT 180 DEGRES AS IT IS MARKED LH AND RH AND IT ALSO HAS A WIDE TAB THAT DOES NOT FIT MY HSGS. THANKS AGAIN. IF YOU KNOW WHERE I CAN PURCHASE ONE I WOULD APPRECIATE IT.
THANKS AL71
(quoted from post at 07:58:55 03/08/15) THANKS FOR THE REPLIES. THE REAR LENS THAT I HAVE SAYS SEALED BEAM AND CAN BE USED FOR RIGHT OR LEFT LENS BY TURNING IT 180 DEGRES AS IT IS MARKED LH AND RH AND IT ALSO HAS A WIDE TAB THAT DOES NOT FIT MY HSGS. THANKS AGAIN. IF YOU KNOW WHERE I CAN PURCHASE ONE I WOULD APPRECIATE IT.
THANKS AL71
I've never seen one with "sealed beam" on it. I'm guessing that what you have is NOT original to the tractor, especially since it really doesn't fit.
Should be able to find a new lens right here on YT.
