FH Spoke Rims
Mark Poss
I am wanting to put a set of weights (F&H161 and F&H 162) on my F-30 that has 28" F&H round spoke rims. The center hub where the spokes tie into measures 9" the inside of the 161 weight measures 12". Will these bolt on alright with J bolts? Any help is appreciated before I go through a lot of lifting for nothing. Thanks, Mark.
they will center up ok . you just can't hang them on the center hub like you can on the 36" wheels , for some reason it sticks out more than the hub on the 28s
Where are you? There's a set that came up for sale on Watertown NY craigslist yesterday. $150 for the pair. Not sure if this helps you or not.
