McMormick Deering Tractor
Taylor88
Who can tell me about this ole tractor, Engine is loose, turns over. What s it worth?
Looks like an Industrial 20. Had same motor as the 10-20. Used a lot of these in mills and other applications such as road grader power. Could be a 15-30 look under fuel tank behind engine for serial tag. Tag could be on cab like the Industrial 20 that I know of
Was told tractor was used as road grader. The engine is 4 cylinder 437CC stamped on block. I have the tractor. Im located in southern KY
depends on what front axle is under it and what the rear platform is like. worth more if it still has the pintle hitch setup and not switched to a drawbar.
ive got 2 of them. one was 800 and the other was 500. both ran and one had the inline generator and factory starter setup
Taylor, my PM is open. send me a private message and I can reply with my email. I can also call you to discuss the f14 as well.
(quoted from post at 05:03:27 03/03/15) I sent pictures to the email, The email will not go through, says invalid. Can I text you pictures?
weird......that's my email address....lol
5one5 49one zero622
kinda weird to see it has a belt pulley on it with the cast industrial wheels.
This tractor has an in-line generator on it which is very desirable and valuable. Also the manifold looks good which again is a big money plus. Does it have the aluminum tag still riveted to the gas tank support right behind the engine?
in the last picture posted, the serial number is stamped into the flat boss cast into the block. If you could get those numbers, that would also be helpful.
Also the 437DC part number on the block is for the W30, F30, and 1020 blocks/replacement blocks. They are all one in the same from the base block.
Absolutely right, water pump and frame gives it away. Check out the generator, I could use that setup alone.
