PTO bearings 350utility
Looking for a source for bearings. Specifically the two larger bearings in the PTO housing. Bearings on the sun gear. The old bearings were international harvester bearings with the numbers GIC-142 and ST-563. Someone who shall remain nameless ran the PTO to long without oil. No lubrication equals no going.
GIC-142 = ST564 = about $425 at the stealership.
IHC 360142R91
IHC ST564
FAG XF173
Norma-Hoffmann XF173
CASE IH 360142R91
CASE IH ST564
ST563 = about $175 at the stealership
WABCO 905205
SKF 6015NR
SKF 6015NRJ
SKF 6015NRJEM
BCA 115L
BCA 115L3
NAPA 115L
RHP 6015N
RHP 6015NR
SEALED POWER B115R
SEALED POWER F43L15
CHRYSLER Y115L
DODGE 390289
GM 903401
GM 954782
CR 6015NRJ
NDH 43L15
FAFNIR 9115KG
FAFNIR XM75SR
JOY MFG 94009116
MRC 115KSG
ABMA 75BC10XXXG
All Parts 115L
PEER 6015NR
Daimler-Benz 000625536015
IMPEXMETAL 6015N
IMPEXMETAL 6015NR
R&M XXLJ75G
R&M XXLJ75GWC
ASAHI 6015NR
POLLARD XX175C
Norma-Hoffmann 4615
HOFFMANN 6015K
HOFFMANN 6015KR
ZVL-ZKL 6015N
ZVL-ZKL 6015NR
ZF 0635331278
VBF 50115
GPZ 50115
GOODMAN 2170449
FEDERAL 9115CG
KENWORTH KW3237
CASE IH 360139R91
CLARK 743500
CATERPILLAR 6V4508
CATERPILLAR K6L7387
ACDelco 43L15
SNR 6015N
IHC 360139R91
IHC 43L15
IHC GC175
IHC ST563
FAG 4615
FAG 6015N
FAG 6015NR
FAG 6015NSP115
KOYO 6015NR
NACHI 6015NR
NSK-RHP 6015NR
NTN 6015N
NTN 6015NR
TIMKEN 115L Indirect Cross Interchange
