WD 45 Hydraulic Question
keithre
Can a set of rear remotes be put on a 1955 WD45 gas tractor and if yes, does the pump have enough pressure to run a small dump trailer cylinder ?
Should work,but will be slow.The AC tractors of that
era used a high pressure/low volume system.I dont
know if it will have enough oil capacity/volume for
the job.Try it and see.
WD45s had the high-pressure, low-volume system. If it is not
a compatible cylinder, you'll probably blow hose connections
right and left. Plenty of pressure, low volume.
