super c aux. control valve rebuild
dewy
can the valve be rebuilt. messicks cant get spring or snap ring..in bottom half..top half diagram doesnt even show piston or valve..they can get the seal and boot for it .... can that valve be rebuilt.. the up and down positions, neutral are not felt,,you have to look and see if its going up or down...thanks for any info.......dewy
You talking about the fast hitch valve?, had mine apart about 20 years ago, all I remember being in there is 1 oring and a big copper washer for the plug on the bottom.
yes gab ...took off cap ...snap ring is gone... remove valve from housing.. does any one know if orings are supposed to be on shaft,, ther is two grooves wher it looks like orings go but not sure...off to hardware to see if i can find snap ring.. ...dewy thanks.
