1939 Farmall H
Early Hs used a non-pressurized radiator. The radiator cap is different, it is a round cap, is stamped "water" and will interchange the fuel tank cap. Also, the radiator over-flow tube is in a different location, which requires a "notch" in the grill for the tube to fit. Also, the early Hs used a "dzus" fastener to attach the grill to the radiator.
(quoted from post at 10:05:54 02/25/15) Is the overall size of the radiator the same
jimmy
Yes, the over-all dimensions are the same. When IH came out with new, pressurized style, the old style was made obsolete. If you needed a new radiator for an early tractor, the later radiator was what you got.
Wasnt the overflow on them just like the Aand Bs were just a standpipe in the radiator. The notched grilles were for the pressure systems wasnt it.
(quoted from post at 12:38:13 02/25/15) Wasnt the overflow on them just like the Aand Bs were just a standpipe in the radiator. The notched grilles were for the pressure systems wasnt it.
Nope. I own a 1940 H with the non-pressurized radiator, and also a 1950 H with the late, pressurized radiator. Never been around an A or a B enough to know how they are set up.
My memory could be off, but I think Gene is correct the original early H and M radiators didn't have a external overflow pipe. Some early grills also didn't have the same rear lip the hood rests on or the overflow slot.
(quoted from post at 12:20:33 02/25/15)
jimmy
Overall dimensions match, but the pressure radiator had fewer tubes. The change was made in late 1942 to conserve materials for the war. The wartime radiators had steel fins.
