424 water temperature gauge
I have a 424 international gas burner . The water temperature gauge is broken and I am having no luck finding an exact or similar gauge to go into that 4 inch hole in the " dash " .I realize there are smaller aftermarket gauges but really want one to at least fit the hole even if it not an exact match. The original had water and amp in the cluster.I would need the entire assembly [ tube and bulb]
Call the owners of this page and get the dimensions of the cluster linked below.
I'm pretty sure it will fit, but will have an used fuel gauge.
Gauge
